955 K track
Jay White
02-27-2006 14:41:53
I am looking for replacement parts for the track on my 955K. Are there any other cat dozers whose tracks or any other track parts will fit the 955K. I am looking for chains pads and sprockets. Thanks for any advice.
seann
02-27-2006 16:04:55
 Re: 955 K track in reply to Jay White, 02-27-2006 14:41:53
If you go to the links listed below, it will show charts for U/C wear limits. It lists the D5, 561C, 951C, and 953 as having the same rail height and pin/bush specs as the 955K. This might mean that at least the chains are compatible, grousers may or may not be depending on application. Might be something that'll help expand your search a bit if you're looking for decent used stuff. Good luck...
Replace "insert link here" with crawlerheavven, except spell heaven correctly (i.e. with one v):
Link
http://www.(insert link here).com/wearlimits.htm#Caterpillar
Bob/Ont
02-27-2006 15:12:50
There are lots of aftermarket undercarrage dealers around, Cat even sells a brand of it too.
Later Bob
