D4D battery conversion- four 6-vlot to two 12-volt
chuck McDaniel
03-01-2006 07:05:44
Anyone tell me how to convert my four 6-volt battery system to two 12-volt system?
chuck mcdaniel
03-01-2006 15:15:53
 Re: D4D battery conversion- four 6-vlot to two 12- in reply to chuck McDaniel, 03-01-2006 07:05:44
2 batteries on each side, has an alternator
Bob/Ont
03-01-2006 16:18:27
 Re: D4D battery conversion- four 6-vlot to two 12- in reply to chuck mcdaniel, 03-01-2006 15:15:53
Okay Chuck, it's a negative ground system. Find the cable going down to the starter solinoid. Hook that one to the Pos post of one battery. The cables in the other box should be one going to ground and one jumper over to the first battery. Hook the jumper cable between the battery boxes to the neg post of the first battery and the pos post of the second battery. Then hook the ground cable up to the negative post of the second battery. There should be a disconnect switch either in the ground cable or the jumper cable between the batterys to shut off power when the machine is not in use.
Later Bob
Bob/Ont
03-01-2006 09:29:50
Are they mounted on each side of the seat? Does the tractor have an alternator or Generator?
Later Bob
