JD E7350
ted
11-03-2001 18:23:44
What year would this serial# be 002364U. That is what is on the tag of a 350 JD, 3cly diesel, with shuttle.4 in 1 loader on it. The left steering clutch only works slightly with steering lever pulled all the way. Would this be just an adjustment?? Am thinking of purchasing. Only 1150 origninal hours. What would be its value? Thanks
Matt
11-04-2001 10:23:10
 Re: JD E7350 in reply to ted, 11-03-2001 18:23:44
I believe the serial numbers you posted for that machine are the numbers for the loader arrangments. The serial numbers for the tractor itself are located just below the seat and behind the shifter lever. Should be something like SNT4E3----- T. Maybe someone would be able to tell what year it is if you got the tractor S/Ns.
Bowd
11-03-2001 18:34:34
I have a 350C Dozer spent alot on final drives more than I paid for it. remove the drian plug &check for steel & if has hydralic filter pull it too check for steel . It won't leak muck fluid just what in the filter holder. Hope this helps you .
