JD450C BLADE CHANGE
TJW OHIO
03-08-2006 16:56:53
I AM LOOKING FOR A SALVAGE MACHINE OR PARTS TO CONVERT A MANUAL 6-WAY WITH THE OUTSIDE C-FRAME TO AN INSIDE FRAME WITH POWER 6-WAY BLADE THANKS
jdemaris
03-08-2006 20:16:58
 Re: JD450C BLADE CHANGE in reply to TJW OHIO, 03-08-2006 16:56:53
What model number is your blade? I've never seen an outside 6 way blade on a Deere 450. We sold a lot of 4-way outside blades - and inside 6 way hydraulic blades (with cylinders) or inside 6 way mechancial blades (with hammer-wedges), but I've never heard of the outside 6. Maybe a regional thing? How do you operate the tilt and the angle? Is it pins and turnbuckles?
tjw ohio
03-09-2006 18:32:10
 Re: JD450C BLADE CHANGE in reply to jdemaris, 03-08-2006 20:16:58
the angle is adjusted by pulling 2 pins out of 2 arms that run from the side of blade back along the c frame. the c frame has 3 holes straight,right,and left angle. the tilt is adjusted by wedges.
TimBinWV
03-08-2006 19:28:15
You might try Hurricane Equipt. in Culloden,WV. Guy's name is David Lincolnogger,and he's an arse. But he may have what you need.
tjw ohio
03-09-2006 18:36:21
 Re: JD450C BLADE CHANGE in reply to TimBinWV, 03-08-2006 19:28:15
if you would have the # for hurricane equipment that would be helpful,thanks
Roy Suomi
03-08-2006 19:26:41
Try Ray Snyder Construction Equipment at 330-233-1913. He's in Hanoverton Ohio by Lisbon. I've got used parts from him on several occasions..
tjw ohio
03-09-2006 18:39:18
 Re: JD450C BLADE CHANGE in reply to Roy Suomi, 03-08-2006 19:26:41
i'll give them a try thanks.
