JD 450C Engine Needed. Whole or Shortblock
Uncle
03-11-2006 18:51:47
I am in need of a good used engine fo my JD450C or at least a good Shortblock. Mine now has a rod hanging out the side of the block.
I am in central Arkansas.
Any help would be great.
Brian
JCSinGA
03-12-2006 13:47:15
 Re: JD 450C Engine Needed. Whole or Shortblock in reply to Uncle, 03-11-2006 18:51:47
Engine should be a 4239, theres alot of JD's around with patches on the block to repair just such an problem. Dont think of swapping it out for B Cummins even if it is possible, your JD engine is better than the B.
R-cubed
03-12-2006 12:53:25
The 450A had 57 HP and the B had 65. Chart I have doesn't give the displacement. I suggest putting in a Cummins 4B 3.9 which will outperform and outlast any JD engine. It has 76 HP not enough to tear it up.
Dave in Tx
03-11-2006 20:28:42
do you know what the displacement of the 450c engine is. I may have one.
Dave in Tx
03-11-2006 20:28:18
Here tis
03-13-2006 03:32:49
 Re: JD 450C Engine Needed. Whole or Shortblock in reply to Dave in Tx, 03-11-2006 20:28:18
JD-4-219CID
Uncle
03-12-2006 08:51:14
I don't know other than 4 cyl diesel with turbo.
Maybe someone can jump in here and help us out.
Bran
