JD 650 Dozer Steering Clutch Problem?
Cat Blade 48
03-12-2006 13:59:21
When first moving my 650 after it has not been used for a day or more the left track will not turn if I pull the right lever to turn to the right. After a very brief time of just running it back and forth then steering to the right it will be ok and will operate fine for the rest of the time I use it that day.Any ideas on what the problem may be? Thanks CB48
Roy Suomi
03-12-2006 20:30:02
 Re: JD 650 Dozer Steering Clutch Problem? in reply to Cat Blade 48, 03-12-2006 13:59:21
Possibility of external linkage sticking or rusted?.. I think I would lube the dickens out of the linkage before I would start to trouble shoot a real problem..Always go for the easy stuff first..
