TD-15 150 Steering clutches
Shawn McGettiga
03-12-2006 18:58:13
It will still steer but it's getting harder and harder to pull the levers (though once in awhile they pull just fine). Does this mean I need to rebuild steering boosters. Can I still get parts for boosters.
belleville const, ltd.
04-17-2006 16:25:41
 Re: TD-15 150 Steering clutches in reply to Shawn McGettigan, 03-12-2006 18:58:13
hello,i just changed steering cluches on my td15 ,might be able to help
bob blue
03-13-2006 14:14:11
I have a 151 series. Check the hyd oil for the steering assist system. Filler cap on right hand side sticking thru hood near radiator. I have found that from lack of use , air seems to set up and had to be purgued out of system by taking cap off and working levers. My oil needs changed, moisture from sitting and condensation buildup and oil is milky. Check for good clear oil.
Shawn McGettigan
03-13-2006 19:48:06
 Re: TD-15 150 Steering clutches in reply to bob blue, 03-13-2006 14:14:11
I will try changing oil, and working with cap off.I did'realize this is a closed system.
