D-2 dozer?
tim24
03-13-2006 16:19:02
I Have a d 2 cat that i am trying to put together. The Dozer has me perplexed, the only part # I can find on the dozer is a 63 or 6b then a dash 1861. the push arms hook to a 2" shaft with a bent piece of flat iron and 2 bolts on each side. The side brackets are a 1" piece of iron with 6 5/8 bolt holes that are welded on the side of the roller housing. I removed the piece and found factory cat holes that sit at a diagonal but my pieces are vertical holes. The push pins and where the cylinder fastens are 1" bent in a S shape and are held on with the 6 bolts that have a tapered shoulder on them. the cylinder has a 1" pin that holdes it on. the cyl.would have to have a yoke on each end. I don't know if this is a cat or ?????
