Cat955 Glow plugs
J Schmidt
03-14-2006 06:11:03
On reconditioning the head the machine shop said they couldn't remove damaged glow plugs.I had been using ether but after finding broken rings would like to get plugs working.Any ideas for removal or could a single AC type plug in the intake manifold do the job?
Bob Plumadore
04-12-2006 01:34:26
 Re: Cat955 Glow plugs in reply to J Schmidt, 03-14-2006 06:11:03
E mail me a SN I may have a used set of Pre Combustion Chambers
Bob/Ont
03-14-2006 07:26:44
Are they broken off? They likely don't want to get involved in anything trickey incase they mess up the threads drilling them out. It is good to have them working if you are in temps below freezing. Check into aftermarket chambers. When you get the engine rebuilt you will not need either to start if you have lots of compression and good nozzels.
Later Bob
