580C Brakes
Glenn OH
03-14-2006 23:45:43
the 580C that I bought has no brakes can anyone give me any ideas on fixing? do the back wheels have to come off?
CH
03-16-2006 08:08:29
 Re: 580C Brakes in reply to Glenn OH, 03-14-2006 23:45:43
If you need any parts i carry housings,brake packes,brake shoes and reline kits for the shoes and the packs Email me if i can help and i will send you my link
430WLPG
03-15-2006 18:08:18
No the wheels don't have to come off. Did you check the brake fluid in the master cylinders under the dash? You will have to remove the dash,the easiest actcess. if you have fluid,there is a square housing right in front of both axles on each side.The brakes are in there, there is 2 bolts and 2 nuts that have to come off,there is one larger bolt in the center bottom of the housing that don't need to come out.There is a brake cable and a brake line to unhook also.
