trojan 400 loader problem no foward
mike j
03-15-2006 18:22:33
Hi working on a trojan 400 it has a twin disc trans and converter reverse works fine but when you put it in foward it wont move but the drive shaft from the conv. to trans is not turning so ? is, does the foward reverse shift spool bypass the converter press. when in neut. and then reapply as well as engaging foward or reverse clutch pack when shifted into f or r in reverse it will spin all 4 wheels and wont move in F and doesnt pull the engine down as if it were locked up eitherany help would be appreacited thanks mike
