Komatsu D 21-5
McRay
03-16-2006 15:17:14
Has anyone ever replaced a clutch on a D21-5, in a hard push it acts like the clutch chatters.How hard is it to replace.
McRay
03-28-2006 19:36:41
 Re: Komatsu D 21-5 in reply to McRay, 03-16-2006 15:17:14
Replaced steering clutchs on right side, new brake pads. also replaced seal on rt track gear,and Bearing on clutch release. Adjusted clutch band 2 turns, sys works normal. No problem with maintance all went well.
D. Andrews
03-21-2006 08:24:12
Yes, actually quite easy. Lift and support the side of the dozer you are doing, this can be done with placing blocks in the right spot and lifting with the blade. Remove seat, seat pan, rear cover. once done, remove valve body assembly. Remove break adjusting nut, then remove break and cover assembly. You should now see the break band and clutch pack, remove band. There are 2 sets of bolts on the 2 shafts that come into the clutch housing, you have to turn the clutch to get them all out, once out, slightly pry one of the shafts ( outside one usually moves ) to give enough space to remove clutch pack. Once out, rest is self explanitory, good luck..... .....D..... .
