Case 350 - Spool rebuild
Jon (IN)
03-17-2006 06:32:54
The spool valve on my Case 350 track loader is leaking quite a bit. How involved is a rebuild on one of these?
Windancer
03-18-2006 03:33:09
 Re: Case 350 - Spool rebuild in reply to Jon (IN), 03-17-2006 06:32:54
I just had my gone thru (twice). By now most of these machines have been around long enough that a simple o-ring reseal will not do it. The finish gets scored from sand lying at the top as these are mounted vertical as opposed to the Case TLB mounted horizontal. So it may need a refinish of the spool pieces and grind and polish back to original specs. Or yours may not need same. Mine is a '74 model. I will install a rubber or leather "boot over the top now to impede dirt penetration. If you want to correspond more, e-mail me and further my fone number if desired.
pjurovcik
03-17-2006 08:53:03
I haven't done it, but if you need schematics I can scan them from my parts manual and mail to you. just send me an email and I will reply and send you the scans.
