JD 450 oil pressure sender.
Brian J. Viande
03-17-2006 18:42:49
Hi all, Just got a John Deere 450 crawler loader, 4 cyl diesel.Probably a '66. Some of the gauges need to be rewired, and for the life of me, I can't find the oil pressure sender on the engine. Not even a plugged hole it might go in. Any help surely appreciated. Thanks, Brian
Original Possum
03-20-2006 13:22:15
 Re: JD 450 oil pressure sender. in reply to Brian J. Vianden, 03-17-2006 18:42:49
Make sure you get the right sender! Just got gauges and senders for my 350 and they peg when the switch is on. The JD parts book shows them hooked to the 2.5 volt terminal of the alternator instead of 12 volt positive, and there is nothing like that in my old parts book or service manual!
Tom in Central Pa.
03-17-2006 19:54:45
Sender tap is on the rear motor plate, just below the right rear of the cylinder head, above the starter motor
Brian J. Vianden
03-19-2006 11:14:52
 Re: JD 450 oil pressure sender. in reply to Tom in Central Pa., 03-17-2006 19:54:45
Found the tap above the starter on rear. There's a small brass bleeder valve there. When machine is running oil streams out when opened. I have no idea why this would be here. I suppose i'll remove this valve and put the oil sender here. What do you think. Thanks, Brian
smokechaser
03-20-2006 08:53:10
 Re: JD 450 oil pressure sender. in reply to Brian J. Vianden, 03-19-2006 11:14:52
It sounds like someone plugged off the oil pressure line for some reason. The bleeder valve you found is probably where the sending unit needs to be. I can send you a picture of the way mine is set up if you want. Let me know.
Brian J. Vianden
03-23-2006 16:26:36
 Re: JD 450 oil pressure sender. in reply to smokechaser, 03-20-2006 08:53:10
I,m getting a new sender and gauge, somebody over the years plugged the hole with an old needle valve! Thanks for the help. Brian
