OC-3 Oliver Crawler
Nathan Jones
03-21-2006 10:18:34
I would like any info available for the Ware Loader mounted on my OC-3. The cylinders (all 4) are leaking oil pretty bad. I have one partially disassembled and need to find parts. I need the seals or packings and the brass ends that compress the outer seals. Are these parts standard if I go to an industrial repair shop to find parts?
fort67
03-22-2006 17:15:27
 Re: OC-3 Oliver Crawler in reply to Nathan Jones, 03-21-2006 10:18:34
Most packings are readily available at most good hydraulic places or a forklift dealer. Replaced all my packings and wipes for under $10 a cylinder
jdemaris
03-21-2006 12:42:58
I've got Ware and Anderson loaders on several of my HGs, and all the cylinder parts I've needed were generic and available from just about any hydraulic supply place. Late model HGs and OC3 are basically identical machines other than the ID tags.
J. Schwiebert
03-21-2006 12:40:23
Zimmermans bough out Ware. What type of seals are these seals. There are hydraulic suppliers that cator to this stuff. Get at least two prices as there is a lot of variation in seal prices. Questions
old
03-21-2006 12:19:47
Do a web search for ware loaders I think they are still in business and you maybe able to get parts from them. You also might try Zimmermans 717-738-2573. Also you might check over at cletrac.org, the guys over there may know of places for parts also
