Oliver OC3
Wade Currens
03-26-2006 09:14:13
Hello I just got my OC3 home yesterday But Im in need of a manifold to see if it will run. If anyone has an extra let me know. Thanks Wade
JIM BROWN
03-28-2006 16:14:49
 Re: Oliver OC3 in reply to Wade Currens, 03-26-2006 09:14:13
I have like new manifolds with OLIVER on then off the IXB-3 out off OC3"s Call me 614-402-0908 Jim
Joe Giordano
03-27-2006 09:04:17
I have lots of parts for OC3s and HGs, I have a very good manifold that came off an HG. Eamil me or call if you have not found one. Joe 360-204-1017
Wade Currens
03-27-2006 18:31:44
 Re: Oliver OC3 in reply to Joe Giordano, 03-27-2006 09:04:17
Joe
I sent an email about the manifold.
Thanks Wade
Wade Currens
03-27-2006 18:31:19
Joe
Thanks Wade
Wade Currens
03-26-2006 11:01:04
I tried one from Hercules power unit that I have but even with the offset adapter to get it away from the mag the carb then hits the frame! The original maniflod has the carb mount about 2 inches higher.
jdemaris
03-26-2006 15:15:07
 Re: Oliver OC3 in reply to Wade Currens, 03-26-2006 11:01:04
I've got two machines - HG and an OC3 that both have replacement Hercules manifolds with the offset adaptors. It all fits with mine, but it's tight. As I recall, Zimmermans has new reproduction Oliver type manifolds, I'm just too cheap to pay the price.
jdemaris
03-26-2006 09:30:59
Keep in mind that the standard Hercules replacement manifold for the IXB3 does not work on an OC3 without some modification. Oliver had one that is specific for the HG and OC3. A standard Hercules replacement will not fit because the carburetor will interfere with the magneto. It requires and off-set adapter to move the carburetor back a few inches. If you find a manifold that came off an HG or OC3, you'll be fine. If it says "Oliver" on the manfold, it's a good indicator of being a good fit.
old
03-26-2006 09:21:46
I have one for an IXB engine if thats what your has in it, which it should. E-mail is open
