Hey!...Ash
JMS/MN
03-26-2006 09:43:50
Saw an older post of yours with no response- wanted info on a Gehl 4625 skidloader. I bought a '95 in '98 for 12,900. Dealers here still get about 8500 for them- mine is an SX version, means it has the remote hydraulic for fork, etc. Maintenance has been minimal, mine has about the same hours as what you are looking at. Replaced one axle bearing, one solenoid, welded the exhaust manifold. Manifold breaks from vibration- entire load hangs from one end. Reroute it to the left side, ahead of the lift cylnder instead of to the rear. Add a steel support on top of the engine and all is fine. Dealer said it was a continual problem- I told him to send the engineer out and I'd show him how to fix it. Lift is rated for 1350 lbs (rating is about half what it will do). I know I've slightly lifted, and moved 2800 lb concrete block. SX remote is a bit limited to run a snowblower, unless for short runs. Better to get a 35 series if that is an issue.
