AC HD5 Steering clutch stuck- need advice
Dave Newman
03-28-2006 15:15:20
I have a HD5 with a stuck clutch, the brake works, and the clutch handle has good spring tension ( we just adjusted it) Can I fill the housing with diesel fuel and let it soak, or will I have to remove the clutch to get it free
any help is appreciated
thjanks
Dave
jdemaris
03-29-2006 05:49:26
 Re: AC HD5 Steering clutch stuck- need advice in reply to Dave Newman, 03-28-2006 15:15:20
Filling the steering-clutch housings with diesel fuel used to be our standard treatment when they had oil in them, but not for stuck clutches. We'd fill with diesel, run for a while, then drain. Then fill with laquer thinner, run for awhile, and drain. It's not the best thing for sure, but it sometimes works and gets some extra use out of the machine without a teardown. If your HD5 had fiber clutch disks, they might soak up the diesel and stick like glue. If you have the optional bi-metallic disks, it's not a problem.
hectorgemme
03-28-2006 16:03:24
HI You should removed the stering cluch because they are dry stering cluch and if you fill fuel on the stering cluch he will slipped. HECTOR
Dave Newman
03-29-2006 16:54:10
 Re: AC HD5 Steering clutch stuck- need advice in reply to hectorgemme, 03-28-2006 16:03:24
thank you for the replies
we will pull the clutch and see if we can get it freed up
Dave
