clutch
Raymond F
03-29-2006 20:38:32
I can"t disengage the clutch on my D7 17A dozer. Can anyone help?
hectorgemme
03-30-2006 02:29:38
 Re: clutch in reply to Raymond F, 03-29-2006 20:38:32
HI Is it a dry or wat cluch.
Raymond F
03-30-2006 17:20:39
 Re: clutch in reply to hectorgemme, 03-30-2006 02:29:38
It is a wet clutch
hectorgemme
03-31-2006 03:34:07
 Re: clutch in reply to Raymond F, 03-30-2006 17:20:39
HI You should take off the plate on cluch housing in check inside and check the small gear ho drive on oil pump gear she must be out off shaft and stuck on shifter ,sorry for my bad english but am french guy.
Raymond F
03-31-2006 20:07:25
 Re: clutch in reply to hectorgemme, 03-31-2006 03:34:07
Oil pumpgear is not the problem,thanks for the info.
We were adjusting the clutch when my son engaged the clutch and it just locked in.
hectorgemme
04-01-2006 02:00:06
 Re: clutch in reply to Raymond F, 03-31-2006 20:07:25
HI You need 55lbs on arm cluch maybe you give to much adjustement.
Raymond F
04-03-2006 01:47:13
 Re: clutch in reply to hectorgemme, 04-01-2006 02:00:06
If this is so , what is the answer?
