Hough Payloader Engine
Ben in IN
03-31-2006 05:01:14
I got ahold of a Hough HAH Payloader with a Hercules Engine. The motor is stuck, not a little, but alot. I am looking for an engine rebuild kit, especially a gasket set. Can anyone tell me where I can buy a set?
J. Schwiebert
03-31-2006 10:01:52
 Re: Hough Payloader Engine in reply to Ben in IN, 03-31-2006 05:01:14
Not all Hough loaders used the same size and model Hercules engine. You will need to determine which model engine you have before you can order the correct parts. The most popular engines in my mind for this application would be either some model of a QX or a JX. Start there. There will also be a third and sometimes a fourth letter after the first two. Those will get you a little more specific with the engine model. There may or may not be an identification tag on the block. If not look for a flat spot near the top edge of the block on the side opposite the manifold side. The model number and serial numbero f the block should be stamped in this area. Look on the Oliver form for the post under old dozer. You will find the phone number and fax number for Jerry Biro. He is North America's largest dealer for obsolet Hercules parts. Fax him. Gaskets can be obtained at Carquest and Napa. Questions get back with me before Monday.
