IN 500 LOADER DOZER WONT STEER TO LEFT
MIKE MCKAIN
04-03-2006 00:56:51
I JUST BOUGHT THIS INTERNATIONAL 500 LOADER DOZER WITH A DROTT 4 IN 1 BUCKET ITS A 4 CLY DIESEL Has 3speed's forward and 3reverse,hydro drive (no CLUTCH) just put in one of 3gear's move lever foward or back for reverse. will not steer on left side HE SAID HE WAS DRIVING THE DOZER AND THE LEVER FELT FUNNY AND THEN HE NOTICE IT WOULDNT TURN LEFT. He thinks a pin or something fell out in case, DOES THIS SOUND RIGHT TO YOU, OR CAN SOMEONE TELL ME WHAT TO LOOK FOR, AND CAN SOMEONE TELL WHAT SERIES IS AND THE YEAR IT WAS MADE.
Kurt H.
04-04-2006 06:18:07
 Re: IN 500 LOADER DOZER WONT STEER TO LEFT in reply to MIKE MCKAIN , 04-03-2006 00:56:51
If you remove the seat, down next to the seat there is a cover on each side. It has 8 or so bolts in it. Remove this cover and look down inside with a "light on a stick" and you can see the bottom. It is just a compartment that holds the cluch and brake assy. The pin has a hex sleve on one end and a threaded rod on the other. It will have a ball on each end to fit into the linkage. You'll need a good "magnet on a stick" to fish it out. You do not need to remove anything major if you are patient and a little lucky fishing around. I tie a string to the pin on mine when I remove it for adjustment so if I do drop it, (and have)I can pull it right back out. This pin releases the cluch before the brake engauges. Good luck "fishing".
Kurt H.
04-03-2006 05:49:56
There is a pin that releases the cluch before the brake band tightens. If the adjustment was to loose, it is possible that the pin fell into the bottom of the case. I have dropped the pin when I was adjusting mine and had to "fish" it out. It is no longer available new.
mike mckain
04-03-2006 21:50:29
 Re: IN 500 LOADER DOZER WONT STEER TO LEFT in reply to Kurt H., 04-03-2006 05:49:56
IH HOW DID YOU FISH OUT THAT PIN WITH A MAGNET AND DID YOU HAVE TO TAKE OF THE TRACKS AND SPROCKET. THANKS MIKE
CH
04-03-2006 05:13:40
Sounds like a story from a Used Car Salesman. Only way to know for sure is tear it down . If its a four cylinder it is a Straight 500 I believe 1965-1969 If you need parts or manuals email me for my link
mike mckain
04-05-2006 21:02:10
 Re: IN 500 LOADER DOZER WONT STEER TO LEFT in reply to CH, 04-03-2006 05:13:40
OH THANKS AND CH WHEN YOU GET A CHANCE SEND ME YOUR LINK IM INTERESTED IN THAT MANUAL AND MAYBE SOME PARTS. MIKE smckain@neo.rr.com
