jdemaris
04-05-2006 05:59:04
Regulating valve in reply to Chip A, 04-04-2006 10:49:44
You didn't mention which injection pump it has. This is a very common problem, I used to fix a couple of them a week out in the field. As long as it is NOT an early model with a CDC or CBC pump, and it's a later 450, or a B, with any of the following pump numbers - DBGFC431-2DH, DBGFC431-24AJ, JDB431AL2731, JDB431AL2727, JDBAL2475, JDB435AL2442, OR JDB435MD2802 . . . then it's most likely the pump housing regulator is plugged. When this happens, the engine will start okay, but then slowly lose power and finally shut down. Once it sits, it will start again, and shut down again. You can test it by removing the regulator valve fitting - or poke a hole through it. It is the little fitting that screws into the top of the pump and the return fuel line to the injectors hooks to it. It is two-piece, the actual regulator is the botton half with pipe threads that is screwed into the pump top-cover. It has a flare-adapter fitting screwed into it. Inside of it is a small spring and plastic ball. Just break through it and clean it out, or remove it, and run the machine a little without it - but fuel will run on the ground. What causes the problem has been discussed here ad nauseum. The pump has a plastic governor weight-retainer. It gets hard and falls apart. Then, little bits of plastic run through the pump and get stuck in that valve. If you pull the timing window off the side of the pump - the little rectangle with two slotted screws - you'll probably find a pile of stuff in there that look like mouse turds. If you've never seen a mouse turd - I can't help you. This same problem affected Chevy and Ford diesel trucks also up to around 1985, since they used the same basic pump. If you run the machine with the fitting removed, drilled out, or bypassed, it will run fine for awhile, but eventually, the pump will self-destruct. It may take months, but it will happen. To repair it, it will take a minimum of $50 in parts, and 2-3 hours of labor - to remove the pump, take it apart and fix it, and put it back on. To do that, you need someone who knows how to fix it, or learn to do it yourself, or - pay a very high price to a pump shop. If the latter, you probably will not find one that will do anything short of a standard, and complete rebuild (or exchange) for anywhere from $300 to $700. For reasons I've never understood, many people regard injection pump as some sort of secret science - when in reality, all it is an oil-pump with a few added controls. Keep in mind, if desired, the pump can be fixed two ways - #1 back to original for a minimum of $50 in parts, or for an extra $40 you can convert it and eliminate the plastic retaining ring. One more thing - 350s and 450s are also prone to having clogged fuel-petcocks at the bottom of the tank. It has a passage so small a flea coudn't pee through it. So, check that also.
