final drive oil trans oil
U9 U9 CAT
04-06-2006 05:09:32
D6 U9 CAT Hadn't run in a while milky looking oil in the trans dipstick the one down from the steering brakes, question is the wet clutch and the trans have the same oil sump? Can I drain the oil from the trans and get both of them or is there anoughter spot the dipstick on the side of the bellhousing also is milky looking MIke
hectorgemme
04-06-2006 09:15:29
 Re: final drive oil trans oil in reply to U9 U9 CAT, 04-06-2006 05:09:32
HI The d6 9u have dry stering cluch and the transmission and bevel gear housing have the the same oil but if whant complete change oil you have to take off the two plugs.
U9 U9 CAT
04-06-2006 12:26:57
 Re: final drive oil trans oil in reply to hectorgemme, 04-06-2006 09:15:29
Does she take about 5 gal. of 30W?
hectorgemme
04-06-2006 15:21:57
 Re: final drive oil trans oil in reply to U9 U9 CAT, 04-06-2006 12:26:57
HI The transmission use 9 gal. and final drive 2 3/4 gal and need 80-90 oil not 30 w. HECTOR
U9 U9 CAT
04-07-2006 00:47:35
 Re: final drive oil trans oil in reply to hectorgemme, 04-06-2006 15:21:57
The transmission uses 80/90W
What is the bevel gear?
Does the transmission and the clutch feed of the same oil? Thanks for the info. MIke
hectorgemme
04-07-2006 02:48:20
 Re: final drive oil trans oil in reply to U9 U9 CAT, 04-07-2006 00:47:35
HI The bevel gear is located in the middle compartment of stering cluch case and the main cluch if she is wat cluch use same motor oil. HECTOR
U9 U9 CAT
04-06-2006 12:29:22
i was meaning direct drive not final drive. Mike
