I know preferences vary with these tag trailers as we call them, tandem axle, deck over the wheels with the beaver tail and ramps. When I first started out working as an operator for some smaller excavation companies, locally, I recall how much I disliked loading a rubber tired backhoe on them. Small crawlers were usually much better to load. Frosty deck, be it wood or steel, well that is usually extremely slick and nothing to fool with, if it could not be scraped off and the sun allowed to dry it up, sand, sawdust anything to get some grit on there will work, but you cannot over-do it and have it flying off going down the road. I know one of my former employees lost and totalled a 550 JD crawler, heard the story, might have been a lack of chains and frosty deck, on a turn in the road. With a crawler, when breaking over the center and the front drops down, you can't sit there and wallow, you need to keep going, I'm thinking this is what happened above, like goin through the mud, if you stop or slow down you'll get stuck, it's kind of a weird feeling when on an incline and the nose finally drops down, but at that point, pivoting is really easy, and is why I always believed that you must stay in forward motion and get more weight on the deck. If the tracks are slipping going up, you need to take care of that though. Each to their own on these matters, but a crawler is usually no problem. I lost a 655 Ford on the way up once, and ended up sideways on the ramp, had to work my way off, start over, but needless to say, it was an awful feeling as it happened. These backhoes are heavy on the back end, and boy does that front get light, it happened so fast, I never was to sure as what mistake I made, had loaded it many times before, but each time you are within the edges of the balancing act, it don't take much with some of these, this 655 and the old 580 case models, were always a bit intimidating to load on a tag trailer. The 416 cat was easier. I can recall leaving the hoe unlocked and working my way up over center, using the hoe to stabilize the back end, then folding it up when safely over center. Not for the lighthearted, and I never enjoyed the practice. I'd much rather make equipment moves with a dedicated lowboy tractor trailer set up. Have to wonder if things have changed with trailers and the machinery since then. I used to get sent with a tag trailer, dozer or hoe on, behind a tandem or triaxle with a full load of gravel, or stone on, was nice to have air brakes on the tag trailer. I'm not sure what the minimum requirement is called for but acknowlege what was posted, there is no substitute. I used to try and pull from either when binding a machine down, front one direction back the other, really helped keep things tight, in the middle, I would go straight across. You need plenty of tie down loops or places to set your hooks, I'm sure all trailers have them every so many inches now, it was always a pain when one was too far away, although like I said above I would use offset ones to pull in either direction, especially with a rubber tired machine, the bouncing action always loosened things up, so it's good to be able to see your tie downs in the mirror and find a safe place to pull over and re-tighten. Some machines like the big scrapers you could set the bowl down and eliminate the bounce, but no matter what, the load has to be kept secured and kept from getting in motion, that's when things go wrong quickly. It's best left to the individual as to how they prefer to do it, but a very important part of safely transporting heavy equipment.
