95 Model Backhoe Attachment open center conversion
Mike Naleway
04-08-2006 05:57:48
I have I believe to be an old JD model 95 backhoe attachment from a crawler/dozer. I have mounted it on my MF 204 tractor with not much trouble. The problem is with the closed center directional valve. Can this be converted to an open center type? It is a sectional valve, end plate is a blank blockoff with the o ring grooves, other end is in through center and out through top and bottom work ports. All the spool sections are the same see through center and work ports. I can barely make out the name Cess__(?) Made in USA on the side, Cessna? I am getting #30200 on all of the sections with a different sub number on all, end- 30200-105c, in/out- 30200-1020. I have access to weld/fab/machining, any thoughts?
Lavoy
04-08-2006 15:48:54
 Re: 95 Model Backhoe Attachment open center conver in reply to Mike Naleway, 04-08-2006 05:57:48
I don't think that during that vintage of hoe that Deere was using closed center hydraulics on the crawlers. Lavoy
jdemaris
04-08-2006 17:57:39
 Re: Lavoy in reply to Lavoy, 04-08-2006 15:48:54
95 hoes were used on Deere 400 wheel tractors with closed-center hydraulics.
Lavoy
04-09-2006 07:43:58
 Re: Lavoy in reply to jdemaris, 04-08-2006 17:57:39
Hadn't thought of the wheel tractors other than the Mannheim's, and I was thinking that they were still open center as well.
Lavoy
jdemaris
04-09-2006 08:10:16
 Re: Lavoy in reply to Lavoy, 04-09-2006 07:43:58
I was just working on a 400 with a 95 hoe. It has closed-center hydraulics and a 2.4 cubic inch, eight piston pump. The 300s are set up the same but might have smaller hoes.
jdemaris
04-08-2006 12:37:56
Maybe I stand to be corrected, but I think the only hydraulic control valves that Deere used, that could be converted, had a large port for a conversion plug. You stuck in either an open-center plug or a closed-center plug. I don't think Deere started using them until the mid-80s. Take an older hoe, like a 95 - maybe off a JD 400 or something close - it probably has a Cessna or Gresen valve. To my knowledge, they are not convertible. If fact, the spools were never available by themselves - not even just for repair - only complete sections with the spools installed. Now, if you're wondering if you could do some machining - like grinding a slot on the spools so they passed oil when in neutral positon?? Can't say I've ever looked that close or tried. Seems you'd be way ahead of the game to buy a used control valve off a hoe from a 350 or 450 crawler with open-center hydraulics.
