Hi everyone,I have just removed the blade and chassis frame on my JD450 and have connected the bucket. I don't know if the dozer blade and frame are orginal equipment or not. However, the bucket works fine and I am sure it is the first time it has been connected and used in a number of years (I bought this machine off an 88 yr old guy, who had trouble walking). Using it for the first time yesterday, I seem to have developed a problem when steering the unit. Using the control levers(2) I find the left side one works fine. Using the right one causes the engine to stall if I don't have throttle around 1/2 or more. Would this be something simple as a clutch adjustment or something more serious? Otherwise the machine seems to run fine going both forward and reverse. Machine is capable of lifting the bucket full (about 1.75 yards) of wet clay, so the hydraulics are not too bad. I don't have anything more than an operators manual and a few pics given to me by an aquaintence, to work with. Is there an adjustment for the clutch - I assume that operating (pulling on ) one of the steering levers causes a clutch to disengage and the brake to work, both at the same time, to allow the other track to slew or turn the machine in the direction required. Sorry about the long winded write up - I am new to all this and am looking for any help others can offer. Thanks in advance, for any comments - much appreciated. John. PS: - thanks Roy, for the schematic you sent me, it was received OK.
