Hi JRV, thanks for your feed back, in fact I have quite a bit of formal training on Hydraulics. The main problem is I have been searching for the correct documentation. I have done a lot of work on this machine so far, when I got it it was in bad shape, I had to re build the 4x4 planetary drives, the extendahoe was snapped in two, I've repacked most of the rear end cylinders. I had to completely re pipe the rear end hydraulics, the documentation I have is for a series that is slightly later than mine, this makes it tough to know if I have the hydraulics piped ABSOLUTELY correctly. I am suspecting that I either have 1)pressure bleeding through a broken seal somewhere 2)An improper functioning relief valve or spool 3)Pump malfunction (intermittent) 4)Improper piping to the extradig valve I have gone over and over and over the hydraulic circuits in the book that I have and can see nothing wrong with the piping curcuit (the way I have it , but would not bet my life on it) The hydraulics are only producing about 1200PSI, I had a JCB service guy out here and he checked the MRV on the loader valve body and that was it, he had to go and charged me $350 , $250 of which was travel... I disassembled the MRV off the front loader valve and all passages/poppet seem to be fine.
I wanted to know if the pump was either go or no go ie; if I have 1200 psi, and actuation with minimal pressure on all axes, does that mean that the pump is ok OR Can the PUMB be WEAK? The low pressure in the system prevails 90% of the time and once in a while it kicks in (10%) The low power is evident as the out riggers will not pick up the machine and the hoe main boom can not be lifted when extended. However when the power kicks in everything works with full power. The lack of power is present in the loader as well. I guess I feel the same as you about tracing the circuit and understanding the flow circuit, BUT certain individuals KEEP TELLING me "it's the pump" I dont think they really know, I think it's just the most convienient diagnosis. Do you know where I can get a manual for this machine without spending a fortune? S/N is 322826 and it's an 1987 machine. Very curious that the JCB neve put a cummins in.... everything looks factory style, I don't know the machine's history, but I'm bound and determied to get it running right... any ideas? ps, I'm not a hacker, I care and have respect for the equipment even though the person before me obviously did not. Thanks Mike, Barrie Ontario
