Final Drive bearings MF400 Dozer
Clint
11-07-2001 18:26:10
I am looking for final drive bearings for a MF 400 dozer, I am having no luck. I have the mf part #'s but can't find where to go to get them. I am also in need of some gaskets and seals. Let me know if you can help.
Clint
Ken McWilliams
11-08-2001 19:32:33
 Re: Final Drive bearings MF400 Dozer in reply to Clint, 11-07-2001 18:26:10
Clint,
As far as bearings and seals go, you may want to try your local industrial power transmission dealer. Here in Dayton, Ohio we have Motion Industries, Ohio Transmission, and others.
The bearings and the seals should be stamped with a part number. If you take them to the industrial dealer they will cross reference them. Very rarely do the tractors use a proprietary bearing or seal.
I had to get some bearings and seals for my MF industrial 50 tractor final drive and axle housing. The MF dealer was so expensive that I would have to hock the farm to buy the parts. Motion industries measured the seals and determined a substitute for each one at a cost of 1/4 - 1/2 of the MF dealer.
Ken McWilliams
Dayton, OH
Clint
11-08-2001 20:12:46
 Re: Re: Final Drive bearings MF400 Dozer in reply to Ken McWilliams, 11-08-2001 19:32:33
Thanks for your Ideas. One big problem that I have is that the seals were so far gone that there is no way we can get a number off of it. I have the MF part numbers for the part but I don't have the size or dimention of the the part. If you have any other Ideas please let me know.
Thanks
Clint
Ken McWilliams
11-08-2001 20:38:11
 Re: Re: Re: Final Drive bearings MF400 Dozer in reply to Clint, 11-08-2001 20:12:46
Clint,
If you have the physical remains of the seal (I'm assuming a lip seal in a steel ringed housing) take it along with measurements of the shaft to determine what the ID is.
The supplier has a chart supplied by National Seal or Chicago Rawhide that gives the ID/OD/thicknesss of the seals. Then they can determine a part number.
Ken McWilliams
Clint
11-09-2001 16:28:52
 Re: Re: Re: Re: Final Drive bearings MF400 Dozer in reply to Ken McWilliams, 11-08-2001 20:38:11
Thanks for your input I will try that.
Clint
jack
11-08-2001 17:27:54
have you tried crossing the bearing number.what is the brand and number? gaskets will probably have to be made seal will be a bigger problem
marlowe
11-07-2001 19:46:45
the parts for the 400 will have to come from minnpar parts they bought all massey ind. at the end. you will have to go trought a minnpar parts dealer this one is in wi. if they can get them they will ship call 1-608-788-1025 some parts are no more and they dont make new ones ther are some junked ones out ther good luck check the web for the junk yards
Clint
11-07-2001 20:32:15
 Re: Re: Final Drive bearings MF400 Dozer in reply to marlowe, 11-07-2001 19:46:45
Thanks for the response. Minnparr is one place that I have tried They had two bearings that I needed but I still need two more and some seals. Thanks for your help.
Clint
