Cat 416 Backhoe (1988 model)
sustain-ag
04-19-2006 19:07:16
My boom wont come back all the way to catch in the transport cradle although it comes within a couple of inches. Can that be adjusted with the linkage under the rear control panel? (It is a 3 stick control system.)
sustain-ag
04-20-2006 20:41:47
 Re: Cat 416 Backhoe (1988 model) in reply to sustain-ag, 04-19-2006 19:07:16
Thanks for your replies. I've previously tried both suggestions and even tried running the engine full throttle without luck. When the boom rocks just almost to center all I get is fluid bypass in my boom control valve. I also noticed tonight that the cylinders are completely retracted just before the boom comes to center. Normal?
MSM
04-20-2006 05:17:04
You have to speed up the engine some and pull the boom lever completely,you need the inertia of the boom to get it to latch,it will not power itself overcenter.
Bob/Ont
04-20-2006 05:27:13
 Re: Cat 416 Backhoe (1988 model) in reply to MSM, 04-20-2006 05:17:04
And when you reach the end of it's travel up use the inertia to keep it coming as you push the lever to boom down. You have to practice this to get the boom over center the last little bit and catch the boom lock.
Later Bob
