JD 350 B
Mike M
04-21-2006 07:41:20
Going to look at a JD 350 B model crawler loader. What years were these made ? Anything special to watch out for ?
2x4
04-21-2006 21:33:05
 Re: JD 350 B in reply to Mike M, 04-21-2006 07:41:20
made in 1970-71
Uncle
04-21-2006 19:55:02
Besides the engine and tracks, make sure that the track Idler adjuster is free and will hold tension.
Check for broken bolts in the final housing, and check that the rear cross member is in good shape.
This is a round bar from the front of the right final to the front of the left final. There are 4 large bolts that hold it to the final, and when they wear or loosen it will put a lot of stress on the drives. The unit has dry clutches so you will need to be sure that they are free and not rusted up. These are very handy machines and not bad to work on if they have not been terribly abused.
