HD21 brake problem
Larry Goodman
04-23-2006 10:21:24
Brakes lock up in motion during operation. Feels likes it looses hyd. pressure. Pull back steer levers and they won't release. Any ideas? Thanks Larry.
NC Wayne
04-23-2006 21:47:50
 Re: HD21 brake problem in reply to Larry Goodman, 04-23-2006 10:21:24
If I remember corretly the HD21's use a hydraulic piston type design to release the steering clutches. When the seals in the "piston" go out you'll experience the kinds of symptoms your seeing. The only cure is to open up the rear and rebuild them. If you need parts try The Parts Place. They handle just about anything you might need for the old A/C and F/A machines.
