850 c case crawler problem
Daveminn
04-25-2006 05:47:54
My 850 c case crawler converter guage seems to run in the red after an 1/2 hour of heavy pushing.If I dont rev the engine too far it will stay in the yellow.If I full throttle it it will eventually get back into the red area again.Question:is this dangerous for the converter to run this hot or will it not hurt to keep pushing?Thanks for any help!Dave A
jamesh
04-25-2006 05:59:39
 Re: 850 c case crawler problem in reply to Daveminn, 04-25-2006 05:47:54
Dave, My 850D used to do the same thing.I finally replaced the thermostat on the oil bypass circuit and the problem was solved.The thermostat housing is located directly under the floor plates on the 850D.Hope this helps. Jim
