What hydraulic pump Manufacturer did JCB use
Mike Hamilton
04-28-2006 18:44:57
What hydraulic pump Manufacturer did JCB use on about 1987 JCB's.
I am trying to rebuild my pump now and am told that parts are not available.
The pump part number is 919/27100 looks superceeded to 919/72400. It's a dual gear pump with two separate pumps driven off one shaft with a splined connection on the main P1 pump shaft to the second P2 pump shaft.
I need wear plates, bearings and wear plate seals. the wear plate seals have broken down and the wear plate hole for the shaft is enlarged due to a worn shaft bearing
I want to contact the manufacturer directly. If I get the potential manufacturers names, I'll do the homework from there.
JCB dealer wanted $1500 for the rubber wear plate seals and the bearings (bizarre expense) and then I'm told the kit is not available.
Thanks
Mike
bigrob
04-29-2006 10:55:09
 Re: What hydraulic pump Manufacturer did JCB use in reply to Mike Hamilton, 04-28-2006 18:44:57
Have a look at Ebay item no. 7613222430 (not mine I may add!)
It does say
'This pump replaces all Hamworthy and David Brown twin pumps fitted to grey cab JCB 3CX machines'
Mike Hamilton
04-29-2006 19:48:12
 Re: What hydraulic pump Manufacturer did JCB use in reply to bigrob, 04-29-2006 10:55:09
I'll check it out..
ANDY BUSCHMAN
04-30-2006 05:22:03
 Re: What hydraulic pump Manufacturer did JCB use in reply to Mike Hamilton, 04-29-2006 19:48:12
CHECK OUT WHITEHOUSEPRODUCTSLTD.COM FOR THE CHEAPEST HYD. PUMPS. ANDY
