JD 350C - Noise while backing up
Tractor Seat
04-29-2006 18:04:56
My JD 350C Track Loader makes a rubbing noise when going backward. I suspect reverser problems. Has anyone experienced similar problems, and found a solution? I've only used the machine about 10 working hours since I've owned it, and I always made sure that there was enough oil in all the reservoirs. I really don't know its history prior to my buying it.
Thanks in advance for any help.
Roy Suomi
05-03-2006 09:40:09
 Re: JD 350C - Noise while backing up in reply to Tractor Seat, 04-29-2006 18:04:56
The only noise I've heard from a 350 is a whine from the reverser counter shaft..This is normal..I can't say as I've heard a rubbing noise on these machines..Does it do it with the gear transmission in neutral?? or does it have to be under load..??
