Cat D7 Final
Uncle
04-29-2006 19:39:16
I am looking at a Cat D7 on ebay. Says it has a has the finals out on the right side.
How much are we talking to fix this. I can do the work I just need to know what parts will cost.
Thanks, Brian
DHAZ
04-29-2006 20:20:16
 Re: Cat D7 Final in reply to Uncle, 04-29-2006 19:39:16
If the machine is an older low drive D7 the finals are pretty spendy to work on. A 100 ton sprocket puller is required to separate the sprocket from the live axle so the drive can be disassembled. You will have to have your Cat dealer do this for you. These machines are also infamous for the dead axle spinning in the main frame and needing expensive machine work. Buyer beware!
Uncle
04-30-2006 17:30:50
 Re: Cat D7 Final in reply to DHAZ, 04-29-2006 20:20:16
Thanks,
This is just the kind of info that I need and can save someone a nightmare in repairs.
Brian
