Hi guys, between the JCB and the HD4, I've got my hands full.On the HD4, I've had some advice before and tried it out, here is the thing I need to know. 1) Is it more likely that the Sliders are siezed or that the adjuster nut is siezed, I would like to put the emphasis on one or the other. 2) Should I be worried about the sliders for the Yoke? are they normally siezed, they look like they could easily rust and sieze, and I don't know if the adjuster screw easily overcomes the slider or if the slider is something that normally is trouble. 3)Once free, should I have any trouble compressing the Big spring? I mean I have a 48" wrench so, just wondering if it will still take a lot of torque to adjust once the threads and sliders are free. 4) should the adjustment be made with the track fully elevated, I would guess yes but don't know for sure. 5) with the 48" wrench I can only barely move the adjuster... I can barely moved it, I'm gonna try the torches tomorrow but could use some help in deciding to heat the adjuster nut on the yoke or the slider block... sledge??? I don't know. JD indicated that the nuts are usually stripped at the end of the hex shaft, they are not in this case.
Thanks Mike
