Backhoe for an OC3
Dale Koehler
04-30-2006 08:26:50
I have an OC3 with rear lift arms, similar to a 3-point lift arm on a farm tractor. Two heavy duty external cylinders. I'm assuming this set-up is for a backhoe. Any information is appreciated
Al Gorman
05-09-2006 06:49:00
 Re: Backhoe for an OC3 in reply to Dale Koehler, 04-30-2006 08:26:50
I have an oc3 crawler with rear lifting arms and (2) two heavy duty pistons also. I have a shovel and plow with it. The whole set-up was installed @ ware machine works in ware mass. My model # 3w1 is on the data plate for this loader. I"m looking for a water pump for my oc3, hercules engine 1xb3, any help?
jdemaris
05-02-2006 11:03:12
HGs and OC3s were available with standard three-point hitches. They were intended for Cat.1 hitch work, not for a backhoe. I'm not sure if that's what you have or not. I have several photos of OC3s and HGs with backhoes, but they are all home-made installations.
