TD 340 steering clutch problem
ellson
05-04-2006 05:57:21
I had new 1/8 in steering clutch shoe linings installed in my TD 340 When I set the transmission cover back on I have about 6 inches of free travel in the steering levers with the adjusting bolt removed. Should be 1 1/2" In the manual it says "the boss (bumper lugs) on the back of the brake back up she must be removed by grinding. The entire 1/16 in msut be removed to provide initial adjustment." I assumed since the machine is 40 years old this had been done. Can some one tell me where the boss is I need to grind off? Thanks
rpg52
05-07-2006 18:36:43
 Re: TD 340 steering clutch problem in reply to ellson, 05-04-2006 05:57:21
Hi, sorry you didn't get any help from the red power site. They've been real helpful to me. Here is another site, not as busy unfortunately, but specific to T-340's. Do the TD-340's use different steering clutches? Sorry, can't be more help.
Ray
http://forums.delphiforums.com/n/main.asp?webtag=T340Crawler&nav=start&prettyurl=%2FT340Crawler%2F
rpg52
05-05-2006 10:20:41
Ask this over on the Red Power Magazine forum. You should be able to find someone with the answer there. I've got a T-340, but never had to deal with this problem.
Ray
Rcubed
05-07-2006 12:04:00
 Re: TD 340 steering clutch problem in reply to rpg52, 05-05-2006 10:20:41
He already asked it there and got no help. I think the IH 340 folks are pretty scarce all over. He"ll probably have to get a manual and figure it out for himself. I"ve heard they have planet steering and if true they don"t even have steering CLUTCHS.
ellson
05-07-2006 15:08:17
 Re: TD 340 steering clutch problem in reply to Rcubed, 05-07-2006 12:04:00
I do have the manuals. Thats how I learned about the boss that needs to be ground off The sterering is a planetary system but IH called them steering clutches none the less
