WHAT IS THE REVERSER GAUGE FOR
ROSCO50
05-05-2006 22:34:08
I HAVE A INTERNATIONAL 500 DOZER IT HAS A REVERSER GAUGE ON THE DASH IT SAYS DONT RUN IN THE RED AND SOMETIMES IT RUNS IN THE RED IS THERE A PROBLEM WITH THE DOZER. THANKS MIKE
JCSinGA
05-06-2006 06:08:59
 Re: WHAT IS THE REVERSER GAUGE FOR in reply to ROSCO50, 05-05-2006 22:34:08
I'm not familiar with a reverser gauge, what I've saw on Int. equip as well as alot of Case is a charge pressure gauge.
It lets you monitor the charge pressure is basically all it does, most I've saw dont have actual psi numbers just the green, yellow and red indications.
Running in the red you have a problem, likely it's the pump itself, some equip. have a suction strainer or filter in the line where the pump gets its oil from that may cause a problem.
If you have good enough pressure at start up then as the machine warms up the pressure starts to go down, thats indicitave of a pump.
