raBlue
05-11-2006 14:26:24
Re: AC HD16 crawler in reply to chuck fischer, 05-11-2006 13:59:16
I like the toys also. I have 3 HD21As. Just got the last one 3 weeks ago. 2 of them are cable and the last is a late model all hydrulic blade , tilt ect. All mine are fuel oil converters. On the converters, pressure guage should read up to 40 lbs when you are high rpm on a push. If it goes super high and you have some fuel oil dripping out the bottom of the converter, the return line from the restrictor, mounter by the oil cooler on right side of engine, returning to the tank is plugged. Get the pressure down or you will damage seals. Also grease the three grease lines into the converter every 20 hours with several pumps each fitting. For Manuals, go to E-bay, heavy equipment , manuals, Allis Chalmers. There were 13 listed there , 2 HD16 DP models, $5.00 Just keep watching the site, they will show. Got the complete hd21 set, all models, engines, and accessories, $45.00. Bob
