Case 350 - Engine Removal Problems - PIC's
Jon (IN)
05-10-2006 06:53:50
third party image
Here is a picture of where the engine seems to be stuck, not allowing me to remove it. Is this a dowel pin? It wouldn't be bolted from the inside the housing, would it? If I looking into this "hole" the tip is painted orange. The engine is free at the bottom where the studs are, and a 1/2 gap can be gotten at the bottom, but it is stuck around the area marked up to the top.
Thanks,
Jon
cnj152
05-10-2006 20:24:35
 Re: Case 350 - Engine Removal Problems - PIC's in reply to Jon (IN), 05-10-2006 06:53:50
Jon; There is a stud on each side of the block a the top. You should be able to get the nuts off from the rear. Hope this helps.
Jon (IN)
05-11-2006 13:45:34
 Re: Case 350 - Engine Removal Problems - PIC's in reply to cnj152, 05-10-2006 20:24:35
That's kind of what I was afraid of. The manual just mentioned the 2 studs at the bottom and one in the front. I was hoping to remove the engine without removing the shuttle shift unit. There's no way to get to those nuts without removing that unit.
Thanks,
Jon
Another pic
05-10-2006 09:46:23
third party image
another pic
just a thought
05-10-2006 12:15:11
 Re: Case 350 - Engine Removal Problems - PIC's in reply to Another pic, 05-10-2006 09:46:23
Don't know for sure on that model but, i tore into a massey here while back forget the size but after removing the fuel tank found there was 2 bolts from the back side that was the same size as the others but they were allen head or hex head about 3/8 or 7/16 don't remember for sure but that could be your problem and if it is they are a bugger to get to good luck and don't break anything that could be expensive to repair. leo
