New Holland 565XL Skid Steer Issue
Jason Micale
05-10-2006 08:24:56
A friend has this 565XL skid loader that is having a difficult time moving. The parking brake is very stiff to move. When the brake is released and he tries to drive the loader, it shakes almost violently.
Does anyone have experience with the brake?
He purchased the service manual by NH is taking forever to ship it.
RodInNS
05-12-2006 18:41:21
 Re: New Holland 565XL Skid Steer Issue in reply to Jason Micale, 05-10-2006 08:24:56
The parking brake on that machine should be a mechanically activated disc brake, which is located in the center of the final drive. If you flip the seat up, you should see the brake linkage at the handle. Follow that down the spring loaded rod to the lever that activates the cam. There is a lock bolt on the back side of the lever. Loosen that and slide the lever off and reposition the lever to either tighten or loosen the brake. There is a detailed instruction in the operators manual. This adjustment must be done on each side. I've described the procedure for my LS170, but it should be the same, or very similar on the LX... HTH.
Rod
JMS/MN
05-11-2006 07:15:30
Is it a mechanical or electric brake? Sounds like it is not releasing. Sometimes it's controlled by a solenoid- that may be bad. My Gehl 4625SX shakes like that if the belly bar is not pulled down, or the brake switch is on. Either way, the solenoid is not in release mode.
