JD 450 Question about broken trans cases
Uncle
05-11-2006 19:28:18
I have had several people ask me about my JD 450C. These people are asking if I have had any broken bellhousing or Trans housing bolts. At least three have told me that if you push a tree or load off center on the blade it will bust one of the housings. I thought that you got broken housings from loose bolts.
Any truth to their remarks?
Brian
Roy Suomi
05-14-2006 03:58:44
 Re: JD 450 Question about broken trans cases in reply to Uncle, 05-11-2006 19:28:18
About the only time I see broken housings is when bolts are left loose , and housings are allowed to move around...Sometimes broken engine frame rails can cause this too...
TimBinWV
05-13-2006 18:53:56
My Dad had a 350c and it stripped out all of the transmission bolts at one time or another. I over-sizes each at least once and had a machined stud made at least 4 times. I finally cured it by plating the main frame to the final drives. I used a piece of 1" plate with 3 boltholes for the frame and had a piece of 3/4" plat cut to fit the contour of the top front 3 bolts on the final drives and drilled them to fit.Added longer bolts to the finals.The problem stems from the fact there are no bolts from side-to-side on the 350. Only from front-to-back.All the pressure is transfered ,ultimately,to the threads of the bolts,verses the shear factor of the bolt. Of course,that's only my opinion..... Dunno how much difference there is in a 450....
2x4
05-11-2006 22:12:19
friend of mine was rough on his logging dozer (JD 450) & broke out the original 5/8" bellhousing bolts. Drilled out the bellhousing & used 3/4" bolts & broke them out too. Drilled it to 1" & put in 1" Caterpillar bolts & that held. Another friend used his 450 for 20 years & original bellhousing bolts are still in it.
