cat powershift linkage worn-no neutral?
DaveK
05-15-2006 08:18:51
my Cat powershift linkage(977)is worn to the point that the neutral position doesn't really exist,just has forward 1,2,3 and reverse 1,2,3..The trans does have a neutral position,(yes it does work)but the linkage doesn't seem to want to allow it to stay there..is there a specific linkage bar that needs adj from anyones knowledge? any help appreciated
Bob/Ont
05-15-2006 16:35:28
 Re: cat powershift linkage worn-no neutral? in reply to DaveK, 05-15-2006 08:18:51
Dave your likage is just badly worn out. Take off the floor plates and remove the shift lever. Change the bushing in it aswell as the spacer and bolt. This will eliminate most of the problem but any of the rod ends having wear should be changed too. Then you will have N123 again.
Later Bob
DaveK
05-18-2006 03:05:24
 Re: cat powershift linkage worn-no neutral? in reply to Bob/Ont, 05-15-2006 16:35:28
I gotta get that hornets nest outta there first-
