Case 350 which lubricant
ohlinger
05-19-2006 18:10:39
I have a new to me Case 350 dozer with a diesel engine. Sometimes when I put the machine in reverse, it will not move. I seem to always have forward. What type of oil goes in the section that the forward/reverse selector is attached to? This section is attached to the engine. There is a dip stick near the brake pedal that is used to check the level of the fluid of this portion of the drive train. I checked the level of the fluid and none is showing on the stick. Could this be my problem? Thanks for your help.
marlowe
05-19-2006 20:14:21
 Re: Case 350 which lubricant in reply to ohlinger, 05-19-2006 18:10:39
as long as it is low CHANGE it and put new filters on. TCH [ from case]is what should be used or something that will match TCH and make sure it will match the TCH spec.
