Case 450B Bottom Track Roller Seal
Charliet
05-24-2006 17:37:21
I ordered a bottom track roller seal kit from the local Case dealer (about 60 miles away). Received the kit yesterday via UPS. The instructions (in the kit) for installing the rubber "bellville" seals indicates that the two metal sealing rings (two on each side) must be "held together" with a "plastic retainer band" and then the "bellville" washers are to be installed on the "unitized sealing rings". There were no "plastic bands" in the kit. How does one install the metal sealing rings and the rubber "bellville" seals without the "retainer band". Can it be done properly?
