HD11-Positive ground?
Eric in CA
05-30-2006 06:33:11
I recently purchased an old HD11S, I believe it's a 1960-62 vintage. It's got a 24volt system, but I see that it's got positive to ground. Is this correct, or did someone just hook it up wrong? Also, did AC use different serial# series for different versions of the HD11? Mine is ser# 1979, which if you follow the HD11 charts puts it in the 1950's, but I believe the HD11S came out in the 1960's. Thanks.
JMS/MN
05-30-2006 07:18:06
 Re: HD11-Positive ground? in reply to Eric in CA, 05-30-2006 06:33:11
Likely the pos ground is correct, since all AC was pos gnd til later. Dean's book explains the confusion with the HD11- Series A was 1955-1970, (#101-14681+); 11S and ES were 1967-1971, (#1-1044+). Many options in tracks, transmissions, end use, etc. Does not list ending numbers.
Eric in CA
05-30-2006 11:05:29
 Re: HD11-Positive ground? in reply to JMS/MN, 05-30-2006 07:18:06
The other problem with the years is that my HD11 has the old Lanova diesel engine, which was supposed to have been replaced by the 10000 series in 1963.
