IH500C pump drive.
Eric in CA
06-04-2006 06:28:50
Hi all, I just pulled my pump because I suddenly lost hydraulics and found the drive was the cause. Looking in my manuals I see that my drive doesn't match anything shown. My pump has a splined input shaft that slides into my now stripped hex drive coupler. Anybody know if this is a correct drive? Anybody have a drawing? My coupler setup didn't have a spring, but I'm thinking it should.
woodsman
06-05-2006 19:27:38
 Re: IH500C pump drive. in reply to Eric in CA, 06-04-2006 06:28:50
Sounds like the pump was chaged over at some point, the originals had a shaft with a woodruff key and it fit into an adapter that went on the pto pulley hub. You may to get a machine shop to make you a new part.I have drawings but I don't think they will do you any good. Let me know.
Eric in CA
06-06-2006 05:49:00
 Re: IH500C pump drive. in reply to woodsman, 06-05-2006 19:27:38
Hi Woodsman, I did verify it's a custom setup. Luckily the splined coupler had the company name "Hub City" stamped on it. I still have to modify it, but I'm gettin it done. Thanks.
Woodsman
06-04-2006 16:17:55
Where was your pump mounted?
Eric in CA
06-04-2006 17:30:00
 Re: IH500C pump drive. in reply to Woodsman, 06-04-2006 16:17:55
Hi Woodsman, My pump is front mounted just like the manual shows. Just the coupling is different. It has a splined shaft on the pump, a coupler that's splined inside and hex outside, and the intermediate piece has two posts that slip inside holes in an aluminum piece on the crank hub.
