Axle straightening/question for TimBinWV
Jim in Oregon
06-05-2006 19:53:15
Hi, I'm still trying to straighten my bent 2" pipe axle. It is bent up, like they high centered or something. I put jacks under both sides of the axle, then I put a crosstie(2x2 square tube)on top of the axle. then I put a chain around the bottom of the axle to the top of the jack. I only had a 6 ton jack, possibly not heavy enough, because it didn't seem to move any. Would a 12 ton jack work better?
Thanks,
Jim in Oregon
marlowe
06-06-2006 05:51:17
 Re: Axle straightening/question for TimBinWV in reply to Jim in Oregon, 06-05-2006 19:53:15
all trailer axles have a high center in the axle if i'm reading your post right i don't think your axle is bent
Heat Houser
06-05-2006 20:11:22
Before I spent a lot of time trying to straighten it, I would take a close look at a new axle. Most axles appear to be bent up in the middle to provide camber for the wheels. I have not measured the bend but my recollection is it is about one inch of upward bend (more or less) in the middle of the axle.
Camber - The angular relationship of the wheel to
the road surface in the vertical plane. Axles are
typically built with a pre-determined bend in the
tube that compensates for the expected
deflection under load. Ideally, the tire footprint
will contact the road evenly across the width of the tread.
Dexter Axle Link
