RodInNS
06-08-2006 18:11:16
Re: How do I do it? in reply to ETD66SS, 06-06-2006 08:27:17
I think I'd set the perimiter of the final size, and then allow a bit more for the clay liner, if you're going to do that. You'll have to remove more top soil to make allowance for the liner. I guess the first thing I would look at is the ground type. If you've got wet ground, or ground that has potential to make water, you want that pond dug, formed, lined and finished as quickly as possible, or it's not going to be finished. If water is a problem, I'd push the topsoil out to one side with the 6, and the clay out the other side or an end, and just pile everything up. Get the hole finished. Then you can use the truck and hoe later to do your landscaping. Otherwise, if you've got time, and water isn't a problem, just dig the topsoil out with the hoe, and load it right in the truck.... Around here, if we're digging, we get it done as quickly as possible. I often have a trash pump on hand too.... Do watch out for that glacial till, and even the clay when that starts getting wet. A good anchoring is often only a turn of the tracks away. If you do get stuck, just get somebody on the 6, and take the hoe, set the outriggers down good, and drag her out with the hoe. You'll want a good chain or cable for that... Timewise, I'd think 2-3 days would be time enough to dig that size hole with that machine. It depends on the digging. I've put a hole in the ground, probably a little less than half that size in about a day. That said, I hit glacial till after about 4-5 feet, and then it got to be hard going. I was on a D4H, which is near the 6c in tonnage, but short on power. Just keep the pushes short, and the slopes manageable.Rod
